Click for Volvo Penta parts and manuals!
Results 1 to 5 of 5
  1. #1
    Question Glastron GT185 4.3 Liter Rev Limiter Top Speed issue
    I have a 2014 GT185 that used to do 58-60 MPH per gauge. Rev limiter never kicked in, motor sounded fine into 5k RPM range. Over the last 3 years rev limiter kicks in at 4.9k RPMs and bareley does 48. Prop is same size as I have always used. Any input would be appreciated.
  2. #2
    Default Re: Glastron GT185 4.3 Liter Rev Limiter Top Speed issue
    Speedos on dash are horribly inaccurate likely you are going just as fast and guage is reading differently. I suspect a out 50 is top end for this boat typical bowrider wont hit 60… Verify speed by gps app on phone, check tach vs shop tach dash tachs are also known issue points
  3. #3
    Quote Originally Posted by Dieter View Post
    Speedos on dash are horribly inaccurate likely you are going just as fast and guage is reading differently. I suspect a out 50 is top end for this boat typical bowrider wont hit 60 Verify speed by gps app on phone, check tach vs shop tach dash tachs are also known issue points
    No, Boat does not go near speed it used to. I woudl know. It used to rev smoothly to 4-5K RPM's in the past for short bursts without limiter ever kicking in. Had tune up from local marina and has never run right since.
  4. #4
    Thumbs up Re: Glastron GT185 4.3 Liter Rev Limiter Top Speed issue
    Quote Originally Posted by Whaler1 View Post
    Problem Solved, Reset tachometer on Faria gauge by depressing and moving back and forth. Set back to location#2 for 6 cylinder. Boat builds up to speed without rev limiter kicking in below 5k.
    I had spoken to two different marine mechanics and they never mentioned tach reset fix. I read about this fix on another thread within Marine Engine.com
  5. #5
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    890
    FWIW, The best my 2300 Holley equipped 2008 Glastron GT185 4.3 has been 54 mph per gps on flat water.
Similar Threads
  1. 2002 Johnson 55HP Enforcer Rev Limiter Issue
    By thebrokenjohnson in forum Johnson Evinrude Outboard Forum
    Last Post: 02-24-2019, 05:45 PM
  2. Power tilt relay switch for 5.0 liter vol penta 2004 Glastron 249
    By Steven Headley in forum Volvo Penta Gas Engine Forum
    Last Post: 08-07-2016, 11:46 PM
  3. Glastron 205 GT no speed indication
    By hytron in forum Mercruiser Sterndrive Forum
    Last Post: 10-13-2015, 10:31 AM
  4. Replies: 2
    Last Post: 06-10-2010, 01:22 PM
  5. Speed RPM and oil leak AQ130c 17ft Glastron Bayflyte
    By wa2kjc in forum Volvo Penta Gas Archive
    Last Post: 06-28-2006, 08:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
