Click for Honda Manuals, Parts and Model Guides!
Results 1 to 9 of 9
  1. #1
    Default is this water in my gear oil?
    Hi I drained my gear oil a week ago after a day on the lake (it was previously changed before storage) and it had a murky look to it. I put in this mason jar for 5 days and its been settling. Look like water to you guys?
    Thanks for your help.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	26777   Click image for larger version.
  2. #2
    Join Date
    Sep 2010
    Posts
    21,919
    Default Re: is this water in my gear oil?
    It does not look good.----Install a seal kit.
  3. #3
    Quote Originally Posted by racerone View Post
    Was really hoping you were going to say its all good. That look like water to you?
  4. #4
    Join Date
    Jul 2014
    Location
    Buffalo, NY
    Posts
    233
    He only has decades of experience and is just guessing and likes wasting his time giving people free professional advice....
  5. #5
    thanks that is a super useful comment
  6. #6
    Join Date
    Jul 2014
    Location
    Buffalo, NY
    Posts
    233
    Your answer is in post 2.
  7. #7
    I can't tell anything by those pictures.
    Gear lube floats on top of water. When you open the drain plug on the lower unit, if there is water in the lube, it will come out first (usually pretty clear and easy to see what it is), followed by the lube. If it's just been a few minutes since you've run it, it may appear milky, something like the color of coffee with a lot of cream in it.
  8. #8
    When I've had a little water in the gear lube it comes out like coffee with heavy cream if theirs a lot of water it will drain straight water initially then a mixture of oil / water. That probably is water, you could drain it re fill then run it and re check it. If you take it to a pro they can pressure test the gearcase for you, save you some time diagnosing.
  9. #9
    yeah thanks I am just going to have it pressure tested for peace of mind. From what I have read its far better to just fix it properly over damaging your gear box in the long run. thanks
Similar Threads
  1. 12V71 Twin-Disc Gear Water in the Gear
    By aronda in forum Detroit Diesel
    Last Post: 02-17-2020, 07:07 PM
  2. Water in gear box
    By Peter Cameron in forum Ford Lehman
    Last Post: 10-15-2015, 03:04 AM
  3. 1976 15 horse... water in gear oil and grease/oil in water cooling
    By 76evinrude15 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-31-2011, 05:10 AM
  4. Water in gear oil
    By fireguy in forum Mercruiser Sterndrive Archive
    Last Post: 06-19-2008, 12:15 AM
  5. Water in gear oil
    By rickroot in forum Mercruiser Sterndrive Archive
    Last Post: 06-03-2008, 12:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
