Results 1 to 4 of 4
  1. #1
    Default Recoating Glass Mat Floor and Inside of Hull -- What Material to Use?
    I am in the process of replacing the gas tank on my 1969 Hydroswift and want to coat the floor and the inside of the hull with something to freshen it up. All of the exposed surface is glass mat and seems to be well sealed and sound. It's dirty though, so I would like to get it all tight before I put a new tank in.
    Any recommendations of a material to use? Some of the glass floor seems untouched in 50 years, but the white areas were coated with something, either at the factory, or after. The sump has a similar treatment.
  2. #2
    Default Re: Recoating Glass Mat Floor and Inside of Hull -- What Material to Use?
    Ok -- I can 't edit my post -- I think the idea was to prime and paint. I am considering an oil-based primer and paint. Although the floor of the hull is included in this plan, it won't actually be the finish of the floor.
  3. #3
    Join Date
    Dec 2006
    Location
    Greenfield Me. USA
    Posts
    6,152
    Ayuh,.... Rustoleum white industrial enamel,.....
  4. #4
    That's a good answer -- that's what I have actually.
Similar Threads
  1. bow glass repair
    By marinoperna in forum General Boat Repair Topics
    Last Post: 09-22-2017, 05:56 AM
  2. Gas filter/glass bowl*******
    By JDT in forum Mercruiser Sterndrive Forum
    Last Post: 06-03-2015, 10:58 AM
  3. weather strips around glass
    By powerplay38 in forum General Boat Repair Topics
    Last Post: 03-30-2012, 10:11 AM
  4. Painting a fiber glass boat
    By stevendaniel in forum Johnson Evinrude Outboard Archive
    Last Post: 06-19-2009, 10:40 PM
  5. Inside Cover Material
    By bkillian in forum Johnson Evinrude Outboard Archive
    Last Post: 06-18-2007, 11:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
