Results 1 to 3 of 3
    Default what is this fuel system valve and what does it do?
    Going through the fuel system on my recent rebuilt engine. Had no ID plate but this is what I know.
    1997 (Pursuit) with Volvo Penta 7.4L FI with Power Steering. One tech says it's a GLi another a GSi and one guy said it's a GXi but I don't see the later one even listed or those years in the charcoal engine. Based on what I've read on this site it should be a 7.4GSIPLK but that doesn't come up in any kind of search, but I digress...
    I'm curious to what this valve is on the hard fuel line and what it does?
    The fuel line spins too easily in my opinion and if it's a valve it doesn't seem to open from pressure (air) placed on either direction. So just curious if it's happy...or not.
    May 2010
    DC Burbs/Maryland Eastern Shore
    2,112
    Default Re: what is this fuel system valve and what does it do?
    Looks to me like the fuel pressure regulator. The vacuum line goes to intake manifold. The hard line coming out of the bottom should be the return line.
    Practicing the ancient art of ren-ching
    Quote Originally Posted by o2batsea View Post
    Thank you. Can you explain to me how a pressure regulator (for fuel) would work between the intake and the fuel system? What are we regulating here and what happens if a pressure is to high (or low). Just trying to understand all the variables in the system.
    If I'm reading this correctly the part does state Pressure Sensor 3854517 for $350!
  1. How do I reconnect the fuel shut-off lever to the fuel valve on a MFS 2.5A?
    By Lug_Nut in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-26-2020, 08:55 AM
  2. Oil Injection System-Fuel System 1992 Johnson 175 HP
    By Fish Reaper in forum Johnson Evinrude Outboard Forum
    Last Post: 04-25-2017, 12:31 AM
  3. Accurately measure fuel burn on 454 return style fuel system
    By n36511 in forum Crusader Marine Engine Forum
    Last Post: 01-10-2014, 03:51 PM
  4. Starving for fuel anti syphon valve or fuel pump
    By stigmen in forum Mercruiser Sterndrive Archive
    Last Post: 06-28-2007, 03:05 PM
  5. Converting Johnson pressure fuel system to pump system
    By tuner in forum Outboard motors archive 2000-2004
    Last Post: 04-22-2003, 10:01 PM
