Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 10 of 10
  1. #1
    Default Neutral safety switch problem.
    We hardly ever get tohatsu motors at shop. Customer brought in a 2001
    40mod2. Key in remote turned to on position, if you move to forward or reverse you get buzzer. I've taken remote off and removed back cover to see neutral switch. Remote in neutral no alarm. I can manually push in button and alarm goes off. Problem is when motor is at idle and you move remote handle l get alarm(buzzer). My question is , when motor is running
    what signals or grounds neutral safety switch. Any advice would be appreciated. THANKS
  2. #2
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    3,172
    Default Re: Neutral safety switch problem.
    What is the actual model? Isd it an M40D2? Full schematics are in the Factory service manual. Here is an exploded diagram of the RC box for the M40D2:
    The buzzer gets power from the 12v source at the RC box.
    Paul
    Certified Tohatsu TLDI Technician
    Hamburg, NY USA
  3. #3
    M40D2. 3C8
    Serial 49386
    THANKS
  4. #4
    Yes red wire top right is + supply and green is -
    When button is not pressed in red wire on side sends + to buzzer, that red sending wire is crimped together with a green coming from ignition switch , then to single red/ black wire to buzzer.
  5. #5
    I went ahead and ordered a ignition switch.
  6. #6
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    3,172
    Just make sure you order the same key number, so the old keys still work.
    Paul
    Hamburg, NY USA
  7. #7
    Thanks for reply. Still waiting for parts.
  8. #8
    Well finally got thermostat and gasket and impeller in today, that customer wanted replaced. Because 1st owner had removed thermostat. Motor runs fine, good telltale as before. The neutral safety switch buzzer is my problem. Paul thanks for control box diagram. As said before we may get 1 of these motors a yr. I've eliminated oil tank float, ( unplugged green wire from float switch with motor running) . Where is temp. sensor on this motor, it has the threaded port on head and the port that uses a hold down tang. Any advice would be appreciated.. Thanks. Or motor wire diagram. Thanks
  9. #9
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    3,172
    Full info is on p 4-11 of the Factory service manual. The overheat sensor, if present, screws into the head and has a bullet connector on it.
    You can dl the owners manual from tohatsu.com for free. Horn diags info is around p 81 or 82.
    Paul
    Hamburg, NY USA
  10. #10
Similar Threads
  1. Possible Neutral Safety Switch Problem. need Confirmation
    By jaybybay in forum Honda Outboard Forum
    Last Post: 06-04-2019, 07:37 AM
  2. Neutral safety switch versus shift kill switch?
    By Pal in forum Mercruiser Sterndrive Forum
    Last Post: 10-26-2010, 01:32 AM
  3. Neutral safety switch
    By redsnapper386 in forum Mercruiser Sterndrive Forum
    Last Post: 09-28-2009, 05:50 PM
  4. Possible bad neutral safety switch
    By rcassar in forum Johnson Evinrude Outboard Archive
    Last Post: 09-09-2009, 11:16 PM
  5. Starting problem neutral safety switch velvet drives
    By chriscraftman in forum Crusader Marine Archive
    Last Post: 09-23-2008, 04:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
