I have a 1986 alpha 1. I just pulled the upper from the gimbal and my drive bellows has about 1 inch of gear oil in it.
Gear oil ran out when I pulled them apart.
I do not have the fill bottle in the boat, just fill from the bottom of the lower unit.
I suspect the seal at the front of the upper drive is bad?
I pulled it to replace the lower shift cable.
Am I correct with my assumption the seal is bad? Is there anything else that would cause this?
Can the seal be pulled from the front and replaced?
