"Woke up yesterday morning to
"Woke up yesterday morning to find my trim/tilt motor running with the motor all the way up and the motor still humming. The switch on the lower cowl did not work when i pressed the down button, so i lowered it via the shifter on the console.Checked it 20 minutes later and the dam thing is in the up position again , although this time the pt motor had stopped running once it was in the full up position. I pressed the down button on the lower cowl and this time it worked.Disconnected the battery so it wouldn't happen again. Now what would make the motor go up by itself??"
