MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
  1. #1
    Join Date
    Jul 2009
    Location
    barrie, on, canada
    Posts
    1
    Default How much water should there be
    How much water should there be coming out of the 2 square holes at the back of the motor.Mine has a steady spray coming out of both. The water seems to be warm and the motor does not seem to be getting hot at least to touch.Any help would be great.
  2. #2
    Join Date
    May 2007
    Posts
    9,267
    Default "They normally spit pretty goo
    "They normally spit pretty good. It's the exhaust that blows the water out of them.
    Those holes are primarily for exhaust relief (reduce excess back pressure) but serve double duty. Once the water has circulated through the powerhead to cool it, it goes down the exhaust housing as well (cooling the exhaust and helping to act as a muffler) - the exhaust also blows some of it out of those relief holes giving you an indication of how well the water is circulating.
    Warm water is ok and as you note, if you can put your hand on the powerhead without getting burned (if you can leave it there for a few seconds), then it's probably cooling properly."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
Similar Threads
  1. Evinrude 6 HP 1974 Water Pump
    By cflong in forum Johnson Evinrude Outboard Archive
    Last Post: 11-30-2008, 04:50 PM
  2. 1998 Merc 200 OB Overheating at High RPM No Water from TellTale
    By longfisher in forum Mercury Mariner Outboard Archive
    Last Post: 07-06-2008, 01:44 PM
  3. 1974 Mercury 40 4HP Water pump
    By westcoastwhaler in forum Mercury Mariner Outboard Archive
    Last Post: 07-16-2007, 03:51 PM
  4. No Water from TellTale MERC XR 150 2005
    By gsmith3286 in forum Mercury Mariner Outboard Archive
    Last Post: 06-07-2007, 12:24 PM
  5. Water Pump Telltale
    By silkscreeners in forum Johnson Evinrude Outboard Archive
    Last Post: 04-13-2007, 02:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
