What gas filler hose to use?
IH82BL8
I'm replacing the gasoline fill hoses on a 1984 Carver 32. Any recommendations on what hose to use, or what hose to avoid?
Thanks.
most of the fill hoses use 1.5" versions...should be rated "A2".
If they need to be changes, probably prudent to replace the vent line as well - i believe they are rated A2 as well.
Stick with a brand name and use high quality stainless clamps and you should be just fine.
Ayuh,..... 'n expose the wire in it to the tank/ fittin's,..... helps with the "Bonding" factor,.....
