What DSS best
"I like the kind that do NOT u
"I like the kind that do NOT use a seal running on the shaft, but rather, a carbon face seal against an applied stainless ring. However, I haven't yet hit the 20 hour mark with my new seal; it's still early!"
"I mean "Packless Shaft Se
"I mean "Packless Shaft Seal" PSS!
DD you mean like this...
"the carbon flange [is] held in contact against a stainless steel rotor which turns with the shaft. The carbon flange is attached to the boat by a nitrile bellow which, with the help of water pressure, produces a constant contact between the carbon and the stainless steel ring." The result is a 100% watertight and totally maintenance-free seal."
"The PSS has been around a whi
"The PSS has been around a while; you either love them or hate them. Like DD said, much better approach than the lip seals.
The bellows appears to be the 'weak spot'. Don't have any first-hand experience with them (deemed them too expensive during overhaul) but there is much on line. I'd bet most of the issues are due to suboptimal install. On most planing hulls, the water injection tube is a must."
