michaeld69
Upon install of new motor a week or so ago, had a water pump leak. Took it back to pump company that had just rebuilt it & they fixed. Hooked it back up & noticed water was leaving the heat exchanger, but couldn't find a drip anywhere.
Today, thought I was going to be able to take it for a spin, but heat exchanger was very low, so I refilled, checked the motor oil (looked great), checked transmission fluid (also great), crunk and within 5-10 minutes was running hot (210 degrees). Immediately shut off, removed [radiator] cap and it was empty! Another inspection of lines & hoses found no drips/leaks. So, I checked the dip stick and found antifreeze/water had filled up the crank case! Looked like cake batter!
I then removed all spark plugs (no water in cylinders). Then I did compression check & was between 150-152 on all cylinders. Where could the water/antifreeze be traveling thru at such a quick rate into the oil pan? Note: as I filled the heat exchanger it took only about 10 seconds for it to leave it. Thought all the antifreeze/water had leaked out during the week through an unfound leak site, therefore wasn't suprised when I had to fill it with about 2 gallons of water before it wanted to hold a good water level.
Please Help! Can anyone give me some advice on a checklist of sorts to dismantle and inspect possible entry areas??
Thanks,
Michael
Thanks,
Michael
