I have a 2006 Mercury 90hp two stroke that has been in storage for a year. When I turned the key on the warning alarm sounded. It is a steady alarm, not intermittent. I have replaced the water pump and it still happens. I have also replaced the assembly switch in the oil injected tank. The alarm still sounds. The water pump doesn't even have a chance to come on. That is how quick the alarm starts. It stops only when I unhook I unhook one side or the other of the two wires going to the assembly switch. Again, I replaced this though. I have added oil to the gas tank and it is hooked the water muffs so I can try to keep starting and diagnose problem. The one shop I got the Tracker at which is 1 hour away wants $95 just to even open the motor and evaluate. Any suggestions would be highly welcomed!
