'91 mercruuiser Alpha 1 V8 (350)...has thunderbolt 4 ignition (module on exhaust manifold NOT box). Problem is not a fuel issue. Starts ok..runs up to 26-2800 rpm ok then stays there....correct prop. Runs all day at this rpm...replaced coil with new, no help. Could the distributor sensor not be advancing the ignition? Thanks
See Mark's response.
The ignition timing is controlled in the TB-IV module, not the sensor....I'd suggest getting a timing light and checking the advance....not having it will definitely limit the RPMs, especially under load..
Ditto Mark's suggestion.
The TB photo-eye system is supplying a "timed" TA triggering event to the module.
The module then progressively delays this event, giving the engine a progressive ignition advance as RPM increase from BASE advance on.
Pick up a Mr. Gasket decal (or one of the many others) for your harmonic balancer diameter.
The decal must be correct for the balancer's diameter!!!
Clean the surface well, and apply the decal.
With your TB ignition system in standard run mode, strobe your timing marks while the timing light is also in "Standard" mode.
Jot down what you see at an array of RPM (let's say in incriments of 250 rpm), and up to approx 3,500 RPM.
These numbers will represent the progressive curve and TA (total advance).
Compare your numbers to the
Mercruiser ignition advance curve that you will find here.
If your numbers are not very close, then you have an advancing issue.
Baring no other issues...... any Marine gasser who's ignition system is not delivering the correct progressive advance, will suffer from loss of power.
Worst case would be a progressive that is delivering too much advance/too early.
