d3washburn
I think I used some old gas in my 135 hp Johnson Outboard motor, and now it will not idle down enough to shift it into gear without killing the engine.
What do you recommend I do to fix this problem and get my motor running good again?
Yes I already drained all the old gas out, and put new fresh gas in the tank.
I tried the following without a lot of success.
Put new spark plugs in.
Sprayed brake free lubricant, and cleaner into the cylinders when spark plugs were out.
Got a couple of gallons of new gas in a portable tank and added one oz of marine sta-bil and 5 oz of sea foam.
Checked and cleaned all the fuel filters and screens.
Got the motor started at home with the muffs on and run about a gallon of the fuel through it. Got a lot of smoke and a lot of gunk (old black oil) come out of the exhaust
Still running very rough, and would stop if I tried to idle it down.
Now what do I try?
Now what do I try?
