Twin Crusaders - Both bog down at 2200 RPMs
lazydaze
I have twin 1987 454 Crusaders. One is a rebuilt Jasper about a year old with an Edelbrock Carb and one is the original with a Quadrajet Carb. I have dual gas tanks and filters. The tanks are linked so engines could pull from either tank. I have put brand new filters in though the old ones looked fine.
Up until 2200 RPMs both engines run great. Beyond that they both begin to fall over bogging down. I guess when the 4 barrel opens up. Even running on one engine it bogs down at 2200 RPMs. Sure seems like a fuel problem but can't figure it out. Either or both engines could pull from either gas tank. Weird that they are both doing it at the same time.
Would really appreciate some help.
that would be the secondary throttle bores.
Even running on one engine it bogs down at 2200 RPM. Sure seems like a fuel problem but can't figure it out. Either or both engines could pull from either gas tank. Weird that they are both doing it at the same time.
Are both engines equipped with the same ignition systems, and which ones are they?
How are you setting up the ignition advance?
What are the ignition systems offering for Progressive advance and Total advance, and at what RPM?
if the secondaries are opening at 2200RPM, that's a problem.....possible but unlikely, especially with different carbs.
Could be ignition as well, but if this occurred at the same time (both engines) also unlikely to be internal.
The filter change suggests the fuel supply plumbing was touched and I suspect a vacuum (air) leak inhibiting adequate fuel delivery over 2200 RPM...
A bit beyond me to some degree. Definitely different ignition systems. The rebuilt engine from a year ago also got new distributor/ignition kit. The other engine had the points swapped out for a sensor a couple years ago. I haven't touched the timing on either engine and can't really answer the remaining questions. I guess maybe I need someone to check timing/ignition.
Any other suggestions prior to getting timing checked?
Appreciate the help.
The fuel system had not been touched prior to the issue occurring. The filter change was a stab at maybe it being a fuel supply problem.
The engines have different ignition systems. The rebuilt engine from a year ago also got new distributor/ignition kit. The other engine had the points swapped out for a sensor a couple years ago. I haven't touched the timing on either engine.
Being anal like I am..... that would bug me.
I would want both engines to be equipped with identical ignition systems, and with identical advance curves.
And BTW.... in my opinion the Pertronix kits are inferior.
They use a cheesy little magnetic embedded plastic Hall Effect wheel in their system.
They also do ZERO to correct an old and malfunctioning advancing system.
There is not a gasoline engine on earth that will produce maximum power until the ignition advance is correct.
We fire up on BASE advance, and we idle on BASE advance.... and that's it.
Many mechanics will check/set BASE advance only and then call it a day.
A real Marine Mechanic will not only check/set BASE advance, but will also look to see what the Progressive and Total Advance are doing.
This requires increasing engine speed while the ignition timing marks are observed with a strobe light.
If the system is not offering the correct advance curve, then internal changes must be made.
Your BBC ignition advance curve should be fairly linear, and it should be "Full-In" at around 3,200 RPM.
At the Full-In RPM, you should see approximately 28-30 degrees of ignition advance.
(See your OEM ignition curve specs for this data)
Yes... use the tried and proven P of E ....... (process of elimination).
Target, test, check, and if need be replace one item ONLY at a time.
Move to the next suspected item ONLY after the first suspected item has been eliminated.
When used systematically and methodically, the P of E will not let you down!
See attached image below.
This is an example only of what your ignition advance curve may look like.
NOTE: BASE advance value is NOT shown in the vertical scale. When you view the line graph at any intersecting RPM, keep in mind that BASE must be added in order to calculate the dynamic degrees of advance.
Example: look at the ignition advance @ 3,400 RPM.
You will see approximately 22* of advance being shown.
Now add a BASE advance of let's say 8*.
This now gives us a dynamic advance of approximately 30*.
Do have a cross feed switch in the fuel line between the two tanks..?. You haven't stated that you separated the fuel tanks, in other words set up the engines so that each engine is taking fuel from a different tank ?
If both engines are sucking fuel from the same tank, there could be a problem in the lines....My first inkling would be to check the anti siphon valves on the fuel lines coming out of the tanks
