Back again guys...
I had very little time home this summer so I only took the boat out a handful of times... The last trip was to Catalina Island and she ran great until I arrived there. As I came off plane and down to idle at the harbor entrance the oil pressure alarm goes off on the starboard motor and then on the port... Both gauges read just above zero!!! Suddenly port motor dies... I hand the wheel over to the wife and head downstairs, starboard is knocking like crazy. No oil in the bilge and plenty on both dipsticks. I left the starboard running and tried to start the port with no luck so I limp in to the harbor. 20 minutes later while waiting for the mooring I get the port to start but I will not run under 1000 rpm... Made it to the mooring on the starboard and called it a day. Next day both engines fired up with 60psi and starboard did not knock at idle with in neutral but did if you gassed it or put her in gear. Ran back home on both motors at a 8 knots port ran great but starboard knocked terribly the entire time and kept loosing oil pressure until it settled out around 5 psi. Definitely not valve train noise so I'm sure it spun a bearing, so picked up a long block. I had taken the boat out the day before the island trip and ran about 20 miles without issue then fueled her up. The only thing different between those two trips and the rest of the summer is I ran with rotella 15w40 rather than 30w. The temp gauges both read fine at the time but I had loaned my temp gun out so I could not confirm that. Any ideas what could cause both motors to lose oil pressure at almost the same time? They have totally separate electrical systems and the only circuit showing trouble was oil pressure so I do not think it was a spun bearing and an electrical issue at the same time. The only thing I can think of us heat and the multi viscosity oil, any input would be appreciated and sorry for the long post.
Thanks,
Matt
Thanks,
Matt
