Before I sell my 200s I want to solve this issue. First off I have a working wire harness and battery cables, I know this because I swapped it from the other outboard that does not give me any issues. I have a no crank/start with key. I have checked main fuse and all fuses in the fuse block. I get the beeps and lights when I turn the ignition on, but when I turn to crank, it is a "weakend beep" and starter does not engage, nor click. I can also hear chattering coming from seems to be the tilt/trim relay.. I tried jumping starter lug with smaller bladed connection on starter and nothing..not even a click... I cleaned all ground wire connections (4 of them that I know of). Then nothing...I swapped ECM and it didn't make a difference...I swapped starter and nothing! I then ran booster cables to positive battery and starter lug and grounded the outboard to engine hoist mount and battery..Still no key start, but I can jump starter with screw driver and make engine turn over. (making progress!) I then swapped main relay on front of engine..nothing! I swapped the entire engine harness with a known working one...still the same results. I cut off the 3 terminal ends of the grounds and replaced them..still the same. I need some help trying to figure this out.
The following is in known working order
The ignition key/cylinder
ECM
Starter
Main relay
New battery
Battery cables/wire harness assembly
ECM
Starter
Main relay
New battery
