Trolling Motor rebuild
wjcap4
Is it possible to put a 24volt
Is it possible to put a 24volt lower unit on a 12volt system simply by changing the voltage feed? It is a foot controlled model.
"Usually the electric motor pa
"Usually the electric motor part is the only voltage sensitive aspect to a trolling motor. Of course, once done, you'll need to supply 24 v to make it run as designed. the wires and switches should handle the change issue free."
