Ayuh,..... Switch yer meter to dc volts,.... ohms ain't what you need,......Trim issues
I have power to trim motor
128 ohms
If I run a jump wire from neg battery post I can drive the OD up at the control throttle
Can’t drive it down with the same process
2005 ssi 236 Volvo Penta 5.7
Any ideas
Ayuh,..... Any that aren't perfectly clean,.....Let’s go over which wires I need to clean
should I get a new trim wiring harness
