How to test a teleflex TT gauge:
Power the gauge by connecting a positive wire to the "I" terminal and a ground wire to the "G" terminal. Have no other wires connected to the gauge. Pointer should read full DOWN for Johnson/Evinrude engines. Next, with the power still connected, short the sender terminal at the gauge to ground. Pointer should go to the full UP position for Johnson/Evinrude engines.
How to test the sender (Johnson/Evinrude):
1. Locate the three pin connector for the trim control harness between the instrument and engine trim harness- you should see the white/tan lead from the sender and the blue/white and green/white motor control circuit wires.
2. With key switch OFF, connect a DVOM (set to read resistance) between the white/tan wire/terminal C of the 3-pin connector) and a good engine ground.
3. With the engine in the full down TRIM position, the meter must show a reading above 80 ohms.
4. With the engine in the full up TRIM position, the meter must show a reading below 10ohms.
5. If the readings differ, the sender must be replaced. If the readings are in the appropriate ranges, check the gauge.
