simonellis
Hi I have a BF6O I am transporting for repair. Can I transport it on its side with the oil still in the crankcase or should it be removed.
Many thanks.
Many thanks.
Not sure why draining your oil makes a mess. On my 40 HP and my 50 HP Hondas the cover you remove sticks into the recess under the drain plug and functions as a funnel draining the oil nicely into a catch can.I have four Honda outboards ranging from 2 to 90 hp. I have never found a way to transport the things other than upright unless you drain the oil, it always makes a huge mess.
Now that I reread it, you are 100% correct. I hauled a 40HP yesterday for about an hour laying on it side with the dipstick side down as per my manuals instruction. I had no leakage at all. The dipstick does fit tight. I could see a leak issue if the rubber top on the dipstick was worn or soft from age. Maybe I got lucky, but I'll take it.I think he meant it makes a big mess if you lay it on its side without draining the oil...
