Redwing1998
I have a 2005 Regal with a 5.7 MAG MPI. The tilt/trim button works only periodically. Right now not at all. When it does work, it works fine. When it does not work (makes no noise at all) neither the switch built into the throttle controller (4000 II series) nor the transom tilt switch work. When it does work, both work.
Any ideas where I should start checking fro the problem? Thanks
