I have, what I believe to be, a 1997 8HP BF8A with the following serial number: BACL 1201051"Found the book- (and looked at mine) so a little correction- they would jam up in reverse.--
If you are still having problems, you may have to go after the innerds. These are for the dark blue and white models.
The cable (17910-881-000) may have unraveled on you. It is held in place in the handle with an anchor block, and clip- it goes into a di-cast slide with a big spiral groove. it is this that actually gets the cable moving. It is moved by a spiral bump inside the moving handle. If any of this has no grease, or not fitted right, you won't go any where. If the cable is not adjusted by the carb, you may have the spiral out of it's groove and jammed.
The rubber cover comes off with a skinny screwdriver and a shot of wd-40. Carefully poke the screwdriver between the rubber and metal then spray and twist- it will come right off. Under the metal moving handle is a round bolt head holding the piece on the tiller. Do not loose it. Nothing else works quite right. Spin the metal handle off and there is the rest of the machine that runs you throttle. Hope you don't need to get this far. Let me know.
9"
Confirm please that I don't have to remove the rubber cover from the pipe in order to remove it.Tom,
The twist grip is held by one screw see part #27 that goes through the end (on the right) of part number 10 http://www.boats.net/parts/search/H... JPN, VIN# B100S-1600001/HANDLEBAR/parts.html
I know this is for a BF100 but it is the same for the BF 8. Once you take the screw out and loosen the tension adjustment the whole assembly will twist off with the rubber cover.
Mike
