StuckInTheMudd
I have a 1987 Reinell 17 fot ski boat with V8 and a OMC Stern drive. I was out in it the last weekend and when I entered the channel I missed one of the channel markers. Needles to say I got stuck. That was the first mistake. The second was thinking I was close enough to give it a little gas and make it to the channel. I wasn't. I turned off the engine and raised the outdrive which gave me clearance to drift into the channel. Once there I lowered the outdrive and tried to start back up. When I turned the key the started would turn a few inches then stop. Like I had a low battery. Tried it again. Same thing. Hence the third mistake. I burned out my starter.
The question is this. I can manually turn the engine over but it tight. Did I ruin something in the gearing? I checked the lower and upper gear fluid and no metal.
Any Ideas? Thanks
Any Ideas? Thanks
