I have a 1994 Chaprarral 2130 Sport that I bought new and have kept it in my garage ever since I took delivery. I only boat in a freshwater lake, wash and clean it up after every trip, so this issue should not have anything to do with corrosion.
The boat came with the 7.4L Mercruiser which threw a rod at the end of 2020 with almost 1,200 hours on the engine. A friend recommended a guy who builds high performance engines for boats and race cars. I looked into that and for just a bit more money than doing a complete rebuild, as of March 2021 I now have a cusotm-built 496 stoker engine. Everything ran great all last summer, but at the end of the season, an electrical issue started happening that I can't figure out. Coming home from the lake, I stopped to top off the tank and heard the buzzer. This is the one where if you turn the key on and don't crank the engine within about 15 seconds, it goes off. The only way to stop it was disconnecting the positive cables from the battery.
Over the winter, I was passing by a West Marine store and picked up a new ignition switch. Yeah, I know that when there's a problem, you don't just start swapping parts but the switch was only around 20 bucks and seemed a good place to start. Put the new switch in and yep, same problem. I have traced all the wires from the ingition swtich and don't see any shorts or bare wires rubbing up against anything sharp.
Any ideas what to check next? Could this be the starter solenoid and how would I check that?
