"I boat in fresh water lake, a
"I boat in fresh water lake, and have Mg anodes on the boat. I also have a Mg grouper anode hanging in the back of the boat, tied into the bonding system of the boat. My boat is a 2007 Regal 3060 with twin 5.0L OSi with XDP-B drives.
I to had the same problems with my forward (larger) port side prop, however it was getting the holes in through the middle of the blade, you could actually stick a toothpick through the blade. That was in the end of 2008 when I had a haul out to replace bellows under recall. Was sent off to a prop shop and fixed. Not much though of it, but did keep a closer eye on the anodes and such, as I thought this was electrolysis as well.
Then this late summer when the next recall on the bellows came out, during haul out I had holes on the forward props again, however this time on both port and starboard, again both large enough to put toothpicks thru in the middle of a single blade. The VP rep came out and said that there were casting issues and authorized two new forward props. The rear props were in great shape. No other metals under the boat were affected, just the forward props. All the anodes look brand new, along with the Mg grouper anode.
Chris"
