LumberGrader
Hi folks
I'm needing advice on replacing the rubber damper and the rubber mounter mounts. How do you tilt the motor away from upper bracket so you can get the little rubber damper on? Theres enough play to get one side on but not the other. Sorry if I'm not using the right terminology. I'm not a mechanic. Am I getting over my head on this? I can get pictures if that would help. I will attempt again to file attach a picture.
Dale
Dale
