Question on 9.9 johnson 1990
pumpman
I have a 1990 Johnson 9.9 hp I know the pee hole is up on the side of motor. But it also has a hole there under the power head in the casing that has a cover over it. Is there supposed to be any water coming out of that.
Test run on a boat or in a test tank with water 8" above the impeller.----A blown head gasket can cause issues.----So a compression test should be done.-----Check head bolt torque.
I took it back apart. Put it all back together put it in a 55 gallon drum. Ran it for while with no issues. Now I'll take it back to Lake and see what it will do. Thanks. I'll let you know
