Douglasdzaster
I got approached the other day at the boat ramp. A gentleman wanted to help me by telling me what I was doing wrong. The motor is on a 16 foot extra wide and deep flat bottom.
When I first got it I had several questions and y’all’s help really bailed me out and got it going. Someone even linked me to an awesome service manual for the motor. Thanks again by the way. After using the boat for a while (this all started 2021). I removed the floor to see if it needed cleaned up and found 3/4” treated plywood and corrosion. So I spent a lot of time getting rid of the corrosion. Built a new floor and decided to just rebuild the boat the way I wanted it. Finally to a stopping point where I can use it for a while before tackling the front deck and painting it.
Anyway the Yamaha is running great. Here’s how I trailer it. At first left the motor down vertical and just went. But I noticed the motor jiggling around and a little bouncing I didn’t like.
We have one road here actually called The Hemorrhoid. Because of how rough it is.
I loaded my boat and began getting it ready for the road. I lift the motor just enough to get a transom saver under it so the angle is not to great then I use a small ratchet strap going from the trailer around the outboard above the cavitation plate and tighten it enough do the motor doesn’t bounce out and fall. Not using a bungee cord because it’s manual tilt.
This gentleman walked over and ask if it was my first boat. I replied no I have had several. A fish and sky then a few bass boats. But that was 20 years ago and this is my first aluminum boat.
He proceeded to inform me that I was messing up my outboard by not leaving it vertical and then ask if I put it in gear while trailering to keep the prop from spinning. I said I never move the gear lever (on the side of the motor/Tiller steer) while the motor isn’t running. Again he said I’m wearing out bearings and seals by letting the prop stay in neutral.
Then my son begins agreeing with him who has never owned a boat.
I started researching online and find there’s actually a lot of conflict between people about both subjects. I noticed Mercury says to put theirs in gear according to a lot of Merc owners its in the manual. Then I noticed people saying Yamaha says to leave the outboard vertical.
I go down rough roads and after noticing the outboard moving around so much I found a couple of cracks forming on top of the transom. I went and had them welded started Douglas what I’m doing and haven’t seen any more problems. So now I’m not letting it go with my son until I see if this guy was right.
I know I’ll get the correct answer on here.
Thanks for reading my story.
ouglas
ouglas
