Pumps water before starting.
Joseph P
1997 50 hp Johnson. If motor don't start right away it will pee water just from turning over. Does that mean thermostat is stuck open? Then run for 5 min. pee water is just luke warm.
Correct ----It indicates that water pump is working.-----Nothing to do with thermostat.----Water will always be lukewarm when running.----If you just bought this motor install a new impeller.----Are you pushing the key in and holding it in while cranking it over ?----And find out why it is not starting up after 3 seconds before you burn up the starter !!
Sometimes I may hold the key in to long & flood it out. I have had the motor & boat for 2 years. Never ran it much, maybe a few times a year. The motor is spotless & never run much by the first owner, still had original spark plugs in it. I will change the impeller this year also thermostat, & plugs been changed. Thanks.
