Nissan outboard 9.8 4 stroke 9.8a.
While I was dropping the lower unit I mistakenly removed the stopper cam rod bushing. Doing this allowed the clutch cam to be pulled out of the lower unit (filled with oil) . When I try to put it back in to the casing filled with oil, (To reattach lower unit) I am having problem.
Is the clutch cam supposed to "catch " and be re inserted? Could it be that I popped out the spring pin causing detachment? Is the fixable? Thank you
i now realize that I should have never removed the cam rod bushing and that I should have removed the spring pins from the joint on the shift rod.
