JohnsrudeV4's
Need to find out the best orifice combination. This motor has .030 over pistons/rings on cylinders #1 and #2. Standard on #3 and #4. Compression is 120lbs. on each cylinder(give or take 2lbs). When I "acquired" it, the float bowls had #69C plugs and #30 orifices. The threads on one side of the carb that holds the orifice screw plug was stripped and pieces of the loose threads blocked the orifice. I found the correct carb and ordered the original #30 orifices and #61C plugs. Is there a more suitable combination for a motor with 2 oversized cylinders? I saw an old post discussing #31 orifices as an option. This motor is just about ready to run, but I don't need to screw up this thing. I have another question, but that'll be on a separate thread. Additionally, I found an easy way to make water diverters that fit great.
