I have two omc tanks (early 80s) that leak from the tank fuel outlet when the cap is closed. If the cap is turned to the first stop the gas stops running. These are single line tanks btw.
Tank connector was rebuilt twice with new orings and front pin seal to no avail.
If the tanks are meant to be sealed then no air gets in and out. Leaving the tank in the sun the tank can build pressure so I don’t see how it’s getting air in to allow the fuel to flow
Also installed new gaskets in cap and under outlet
I’m at my wits end. The only thing I can see is that there is a rubber valve under the outlet that according to Crowley is called a valve assembly and it’s parts 26 27 and 17. I don’t know what it does other than if the cap does not vent then I wonder if this is a vent of some kind
Feedback appreciated.
TIA
TIA
