"[b]quote: " should I leav
"quote: " should I leave it locked down when in operation at all times? "
Yes, the above is what I was responding to with the word "true"!
The latch hooks "lock" it down into FWD preventing the suspension fork from kicking up AFT.
When in FWD, the fork will be thrusting against the set pin (the latch is non-effective until you reverse again).
If you were to REVERSE, the latch unit will then become effective!
It's called a "reverse latch"..... not a FWD lock!
FYI, the transmissioin will go into and out of gear with the drive in any position. This is what you will want to be careful with!
