Oil leak
Jerrys226
After pushing the rpm’s in a storm yesterday, I found considerable amount of o in my bilge and under the engine. Is it possible I did some damage? I was also keeled pretty heavily at times. Any ideas as to where the oil may be coming from?
Thoroughly clean the bilge and wipe down engine surfaces as best you can. Inspect for oil deposits around the valve cover, oil filter, oil filler cap, dip stick, breather and other components. Check dip stick oil level, oil pressure. Do a short to moderate sea trial and reinspect bilbe. Good luck!
