paranoiccritic
Hi All,
I've recently gotten a 90hp 1983 Johnson 2-stroke running. Issues were all related to fuel, and after replacing the fuel pump, all fuel lines, and rebuilding the carbs (twice - the first time I used off-brand gaskets and they deformed, the second time I used Johnson OEM gaskets and they worked like a charm). Compression is good, spark is good, motor runs like a champ now.
I had it on the water for a few hours two weeks ago, and it has been sitting on my boat in my back yard since then (for about 2 weeks). This morning, I noticed a drop of oil hanging from the trim tab, and upon inspection, there was an oil slick on the top of the lower unit all the way astern (on the top of the cavitation plate?), as well as on the sides, forward from the water intake, and there were drops of oil pooling on the bolts securing the lower unit. The oil is clear, slick, and looks like light motor oil. I am concerned that there is some leak somewhere, but this is all way above where the lower unit oil would be, right? And since it's a 2-stroke, there is no oil reservoir or separate oil system in the motor (like a 4-stroke) - what could this be, and how bad is it? Pictures available here:
https://drive.google.com/open?id=1pRi2fTpP3xTYYgMIJpR3ryGoRoUaUkJE
Please advise. Thanks in advance.
Best,
Fred
Best,
Fred
