"I have noise coming from, I b
"I have noise coming from, I believe, universal joint until boat plans out then quite. Seems like only makes noise until strain is reduced on u joint after planing. How do you tell when u joint needs replacing? Bearings on u joint need no add'l lubrication, correct? Also getting water oil mix in drive boot and outdrive. Is seal easy to replace where u joint shaft joins upper unit? Drive boot seems in good condition."
