I have been hearing like whistling noise from my Mercruiser 5.7 EFi Bravo 3 for a long while but no one could point out from where it was coming from. At last after a long story I concluded that its coming from the power steering pump after spraying on some WD40 (Lubricating Oil) on the shaft between the pulley and the pump. This killed the whistling noise completely for a couple of minutes and than it starts again. The noise is heard through all the rev range even sometimes while the engine is on idle. Power steering works fine. Turning the steering either way does not effect the noise either.
According to some research I found out that the p/s pump does not have any serviceable parts inside and also the pulley is mounted on the shaft in a solid way so it does not have any bearings which can be changed or it could be it making the noise. Am thinking of getting new pump because this noise is really pissing me off but before I wish to ask if someone else has ever experienced this problem or anything which could be done since a new pump is a bit expensive !
