CHSKeywest1720
[FONT="]Motor: 97, 75hp,2st, 3 cyl, Mercury Serial 0D283222.[/FONT]
[FONT="]Remote Control: Mercury Remote Control 88688A26 - good condition[/FONT]
[FONT=Segoe UI, Helvetica Neue, Helvetica, Roboto, Oxygen, Ubuntu, Cantarell, Fira Sans, Droid Sans, sans-serif]16' Shift Cable: Removed from boat, I believe to be original, smooth, appears to be in great shape.[/FONT]
[FONT=Segoe UI, Helvetica Neue, Helvetica, Roboto, Oxygen, Ubuntu, Cantarell, Fira Sans, Droid Sans, sans-serif]I have the lower unit off the motor and reassembled after replacing the bearing carrier assembly seals/housing. I'm able to locate forward and neutral by twisting the shift shaft CCW and checking the propshaft for proper output. However, when I click into the 3rd and final detent via the shift shaft (CCW) from neutral while rotating the drive shaft CW the prop will barely spin in the CCW for reverse, I do not hear any engagement of the gears, nor will the prop lock in place.
TLDR? - When my lower unit is off my motor, if I rotate shift shaft (CCW) into the reverse detent from neutral while turning the drive shaft CW, will I hear, feel, see, the prop turn in a reverse CCW) direction? Currently I'm unable to produce the situation above with my motor's lower unit, I believe the issue to be worn follower cam or shift cam. I can locate forward and neutral. I'm unable to locate reverse after reassembling the lower to the motor as well via the shift block on the engine either, I can however find forward and reverse.
-Would anyone be able to provide some advice as to how I should properly setup a new shifter cable after reassembling my lower unit (situation described above)? I know longer have the previous shifter cable as a reference nor do I take the measurement before I remove the previous cable. With my shift block flappin in the breeze due to the lower unit sitting on the ground pending repair, I'm unable to measure for the cables proper location yet.
picture of follower cam and dog clutch would be attached but I can't get it to populate. [/FONT]
