coastal eddy
Ok, I'm new to the forum so Hi everyone and thanks in advance for any help here.
So I go on craigers and see this motor. It's a '84 J25RLCRD and it's brand new. Never been installed on a boat before. With a bit of skepticism I go check it out and this thing is brand spankin new. Allbeit 32 years old. So he was asking $875 and I got it for $800. I think I got a good deal as it was just what I was looking for. So far so good. Obviously a motor sitting for 32 years in storage will need a new impeller so I ordered one of those and it will be here in three days but I went ahead and tried to split the lower end and that's where I'm running into trouble. It just doesn't want to split. It has an extension on it so I began by taking off the four side bolts and it would not split. That's when I noticed the one in the back at the top of the extension so I removed the four sides and the back one on the extension and got the lower end to wiggle a bit but the back bolt is acting like a hinge and although it will wiggle back and forth it will not break loose and come off. So that's where I am. Am I missing something or is it just 32 years of stuck and if that's the case as I suspect it is, How should I proceed to get this pup to break loose? I have a manual coming with the pump kit btw. Also it seems to be having a bit of a problem obtaining full throttle but I am assuming that there again it is just 32 years of carb varnish. I will rebuild the carb if a little carb cleaner doesn't open the jet.? That's the plan! Feel free to voice any opinions about anything here. Looking forward to getting to know you guys.
