ruralcompanion
MFS20C 4-stroke brand new out of the box. Took her out for a very disappointing maiden voyage today. I was all set to putt putt along for a good few hours of the break in period.
Motor starts easily but idles somewhat rough, although I've never had a 4-stroke so I'm not exactly sure how smooth it ought to be. Will idle in N and continue to idle in F or R gear, but engine will not increase RPM when throttle is applied. Many times when I tried to apply throttle it would just cut out and die. Sometimes it will keep running but only the very slightest increase in RPM. I idled up river for a little while but then decided it would be the smarter to just shut it off and ran the trolling motor back to the ramp.
When setting the engine up on the boat I installed a Sierra fuel/water separator between the tank and the primer bulb. The bulb primed up the filter and all the way up to the motor with no problem, the motor started on the second pull. So I don't think it's a fuel feed issue.
I bought the motor online so it hasn't had the pre-delivery inspection done. I'm thinking I should just take it in to my local Tohatsu dealer and have that done. But I wonder if there is something simple I'm overlooking so I thought I'd post here and seek advice. At the least maybe someone could help me with what the possible issues might be.
Thanks for any thoughts and advice. -James
