Rubenjames123
1993 90hp Force. I recently broke the throttle arm on my tower shaft. I have been able to get it out of the lower bearing and have limited movement. The problem I am having is space and possibly the correct removal procedure. The top of the shaft has a 90 degree bend that I am trying to work around. Is this the way to remove, or do I have to push out all the small pins and remove each piece connected to the tower shaft, then remove from the top. Doing this way would require me to remove the flywheel and stator to get the clearance to pull straight up.
I was hoping someone would know a short and easy version to changing this out.
Ray
[email protected]
1993 90Hp Force SN 0e090****
Ray
[email protected]
