This is getting a little bit frustrating.
I'm trying to break in a new rebuild with this Evinrude and it's beginning to behave like a bad omen. Anyway, the motor has been running fine on the hose and in a tank (of sorts) until it was decided to launch and finish breaking her in through a few nice "put-put" rides down the river. Everything was stellar the first night she was in (other than a little bit of weakness in idle) but now I seem to have developed some sort of misfire and cannot go anywhere in gear without it fixed. My question is, once I find out which cylinder isn't firing up, what do I look for and how do I get her fixed?
There is a slight fuel leak in the fuel line where it connects to the motor, but nothing I can't keep on top of for now. Fuel has been run at a 25 to 1 ratio to help with lubrication, but it doesnt' seem to do the spark plugs much good. Upon giving the throttle a few taps by the carbs, I can tell she is building up carbon pretty fast. I can see a few spews of dark smoke clearing out the exhaust when I do that. I'm not trying to tempt fate by giving it a few revs to clear up the smog, because this motor has been running idle long enough in the tank before I launched her. I'm just a little perplexed as to what to expect as the most likely culprit in the misfire situation now. I've done a number of compression checks (without open throttle) and she is giving me around 115psi per cylinder on the nose. COMPLETELY CONSISTENT PRESSURE. I also can see a clear blue spark coming from every spark plug when doing individual checks. No arcing detected at night either. Could this be from bad reeds or something in the carbs? Why would it run so nicely one night and then start breaking down afterward?
Any suggestions would be greatly appreciated. After all of the work I have put into this thing, I am pondering a violent reponse by shooting it with a bazooka or something! At least I could get a little return on entertainment instead of paddling back to shore! LOL.
Thanks in adavnce.
Thanks in adavnce.
