1) If you ski/tube the height is correct...2)If you fish only it needs to come up about 2 inches. RPM needs to be 5500-5900
I agree what is your WOT rpm. You can watch how far the waterline is above the cavitation plate when up on a plane and adjust it so the plate is 1/2 to 1 inch in the water. Are you running at higher altitudes?
Model # j150stlcca . If I move idle screw it changes idle timing. If I move cam thumb screw it does nothing but move camWhat is the model number of your motor? From what I can find you have three adjustments in this order. After you confirm all the throttle butterflys open exactly the same time you adjust throttle pickup at 6-8 BTDC. To do this you run the engine with a timing light at 6-8 degrees BTDC use the thumb screw to center the first small line on the throttle cam center of the roller that opens the carb the adjust the roller so it is barely touching the cam then check that the carbs just begin to open as the first line on the cam passes center of the roller. You can then adjust idle speed with the idle stop screw you want to disconnect the throttle cable to adjust idle speed and then adjust the cable to fit. You want to adjust idle speed in the water in forward gear.
Recap
run engine at 6 degree before TDC
align line on throttle cam to center of the roller throttle butterfly fully closed
adjust roller so the butterflys just begin to open as the first line passes center of the roller
adjust idle stop screw in gear on the water 600-700 rpm and adjust throttle cable to fit
If you messed with max spark advance confirm it is correct.
http://www.marineengine.com/parts/j...Evinrude§ion=Throttle+&+Shift+Linkage
Your idle speed adjustment is #17 in this diagram.
Once you get the throttle pickup correct I imagine it will just jump out of the hole from the videos. Dont be gentle just goose it quickly from idle speed to full throttle. You can get the throttle pickup exact with a alligator clip and a straight wire about three inches clamped it the alligator clip and then clip it to one of the throttle levers on a carb that will tell you exactly when the carbs begin to open you want them to begin to open as the first mark on the throttle cam passes center of the follower roller that opens the carbs.
