moresparks
I have lost a lot of confidence in my twin engine installation .. I know they are 20 years old but I was hoping to extend the life a little longer but they are so fragile!
Having spent months rebuilding the top end of one due to timing belt problems caused by an unseen water leak all seemed fine. Also having replaced all the seals and hoses and it starts great. Several tests after the boat was launched and all looked well. Last job was to balance the throttles between the 2 engines before giving it an extended run.
Then for some reason the newly rebuilt engine wouldn’t idle. Starts fine but if you lower the revs to below 2000 it just dies – really strange as all was perfect the week before and I cannot use a uni-sync tool to reset the carbs.
Now I have since changed the filter, stripped, cleaned and rebuilt carbs again, and changed spark plugs all to no avail. The next test is another compression test and to swap the distributor.
The last time I had this problem it turned out to be the fuel pump – can it be that again? The pump was new last year and has had very little running. I guess its back to basics again but this is really frustrating so any pointers would be appreciated.
