I have a 1987 Mercury 150 XR2 Black Max and have recently started leaking oil from the power trim reservoir on the right side near top seal when trimming down only. The oil also is milky so I believe some brackish water got into the system. Because of this I need to drain immediately and fix the leak.
The power trim tilt has the square pump motor on the right and the reservoir on the left. I have recently added Type F transmission fluid to fill.
How do I drain the fluid (the pressure release screw doesnt seem to want to come out so not taking a chance on breaking that)
Any other suggestions on fixing the leak considering water also got into the system?
Lance
Lance
