2001 Chapparal Signature 28, Just got it, twin 4.3 262 V6's with Mercarb 2 Barrels. is the choke supposed to work? Mine are stuck open because the link goes to a bell crank that is held tight by a screw (no swivel). One is oxidized in place and wont move anyway, (PB Blasted it and it freed up a bit) but the screw on the linkage bell crank is binding the linkage and choke plate open, is this normal or the way its intended to be? The Starb engine took for ever to start, like 3 - 10 second cranks before it sucked enough fuel in. Thats why I was thinkin' choke, and its elect choke heater on there? Didn't know the Mercarbs actually had an Accelerator Pump, so I'm using that as my start enrichment. I release the shifter for just throttle actuation, and start cranking dry then pump the throttle twice after the cranking starts and two turns, fires right up. So, are the chokes actually supposed to be functional? or did the guys before me screw these up?
Greg
Greg
