Temp will be what your thermostat is, do you have 160 in, if so 185 is little high
Steve
Steve, all due respect to you, but if you are referring to Jim's exhaust temps, I don't think that this is necessarily so... and allow me to explain why!
Whether an "open" or "raw water" system... or even for a "Closed Cooling" sytem......, most all sea water is by-passing the actual engine cooling demands.
IOW, the actual engine cooling demands typically require far less sea water than what is actually available if all is working correctly.
For an "open" system, the "thermostat" allows cooling water to "leave" the engine cooling system on an "on-demand" or "as-needed" basis as per thermostat temp setting.
The balance of the sea water is sent right on through to the exhaust system, and is expelled out the exhaust.
This is clearly demonstrated via a cut-a-way-view of a raw water T-stat housing and it's porting.
Would you agree?
I do agree that engine temp may have an effect on exhaust temps, but no where near the amount implied.
Again, this is because most all sea water provided by the sea water pump is by-passing the actual engine cooling demands.
My guess is that Jim's manifolds/risers are beginning to show signs of rust scale restriction, etc.
Being salt water cooled, it may be best to replace, rather than attempt to clean, etc.
Or a sea water pump that needs attention.
The other issue, Jim.... is the thermostat temp rating for a salt water cooled engine.
Salt begins Crystallizing at temps at/near 143* or so (depending on the info source).
Because of this, Stat Temp should not be at the higher end range... possibly best if around 140*!
Most OEM info will imply that a 140* stat be used for raw
salt water cooling.
Once Crystallization begins, it's pretty darn hard to reverse the effects... and this will be in both the engine and the exhaust system.
Edit:
Jim, it may be worth your time to pull the risers, and take a good look at the transfer ports.
You're going to see that these are restricted with rust scale.
Often these can be cleaned, and we can temporarily renew some cooling ability.
Cost to do so would be two new gaskets.
Food for thought!
