Engine shut down results in making 60 miles of a 100 mile return trip on 1 engine. 2007 5.7 MPI’s never missed a beat @3100 on the 100 mile trip up. Stayed the weekend. Started up, fueled up took 113 Gals, restarted & took off for home. Ran for 40 miles @3100 & than it just died. Has to be fuel? Other engine is still running. Switch to the tank the good engine is running on but can’t restart. Change the filter can’t restart. Air bound? Prime by turning ignition on for 5 seconds repeatedly. No restart. Check the test port on the fuel rail we have gas. Check for spark, no spark. Now what? We wrapped a line around the prop shaft & tied it off to prevent wind milling Ran @2100 on one @ about 8 knots headed for home. Did some testing today & found spark @ the coil wire but not @ the plugs. As the engine cranks it sounds like the timing is way off & it wants to run backwards. Remove the tiny “torx”screws holding the distributor cap on. Carbon looks ok. No tracking, no moisture, no cracks. Remove tiny tiny “torx” screws holding rotor. Test with ohm meter @ find a high reading. Change rotor. No Start. Connect coil wire back on the cap & using a jumper from ground held close to the carbon I get a weak spark. Weak coil? Swap with the good engine no start. Swap distributor cap as last resort & it starts. Put bad cap in good engine no start.
