Hi All
I have a 2006 M30A (Carb pre mix 2 stroke). Owned since new, great little engine. The problem is, if I run the engine flat out for a length of time (10mins) then back it of to an idle, it will stall. If I throttle down slowly and spend a minute or two at 1/4 throttle then back off, she will idle till the cows come home.
Also when I flushed her out last night, I noticed steam coming out of the hole at the base of the power head along with water. The water flow was steady, and the tell tale was quite a strong flow. Is the steam a sign of trouble?
Daniel
Daniel
